I’m currently working on my first PCB for a personnal project (air quality monitor board) and I’m having some beginner’s questions so first please pardon my ignorance ![]()
I’m wondering if it is possible to solder 3 sensors with the tools I have.
I have a Soldering station and some soldering gel and I’m would like to solder the following sensors:
The problems I’m facing:
- Bosch BME688 has pads below the sensor, they are not visible when the component is placed on the PCB. The datasheet recommend to solder it using reflow but I don’t have a oven so I would like to know if it’s possible to solder it with the heat gun ? The datasheet is saying that we should not heat the sensor above 260°C (not longer than 20-40 secondes) and I suppose it’s not enough to solder it with my heat gun. Do you think it’s impossible with my heat gun/soldering iron ? If yes, how can we know when it’s correctly soldered if we can’t see the result ?
- The SGP41 has a pad under the sensor and the datasheet is also recommending to solder it using reflow technique. It has around the same limit in high temps.
- What would you recommend to solder the TSL2591 ? Is it better with the heat gun or the soldering iron ?
- JLCPCB is the manufacturer I choose to print my PCB, If the problems mentioned above can’t be solve with the tools I have I’m thinking to use their assembly service but there is also a problem here because the reflow at a temperature of 255°C which is higher than what Bosch and Sensirion recommend for the reflow soldering. They also don’t mention the amount of time in which the sensor will be exposed to that temperature. Am I overthinking or is it also not possible ? JLCPCB assembly capabilities are visible here
Luckily the rest is not that hard to solder ^^ It’s simple capacitors, resistors and other things bigger with no pads at the bottom ![]()
Also if you think I should buy some extra tools don’t hesitate to tell me, I saw some persons having a heating plate to heat up the pcb first, I’m not sure if it’s needed. I also think I will probably need a good magnifying glass so if you have good recommendations I would be happy to hear them ![]()
Thank you for the time you spend on reading my noob problems ![]()
