I pressed 8 to generate a tuning pattern to tune the length of the differential signal pair.
However, the length difference between the two signals was large, so I added a skew tuning pattern.
However, no matter how much I adjusted the skew tuning pattern and generated more, it did not decrease below a certain length.
So in the end, I had to manually add a round pattern to make the signal length similar.
Why doesn’t the length of the differential signal adjust to be the same when adding a skew pattern?
Is this a bug or my mistake?
In other parts where the curved pattern was not added to the differential signal, I confirmed that the two lengths matched after adding the skew pattern.
