Is is possible to move components on from one sheet to another and maintain reference designators? I and cut an paste but the refs turn back to ?'s.
Jacob
Jacob
Instead of cut and pasting, do cut and then edit → paste special. This lets you paste with some options. The one you’re looking for is keep existing reference designators, even if they are duplicated.
If you use paste special a lot, you can assign a hotkey, for example Ctrl+Shift+V
That[quote=“gkeeth, post:2, topic:39400, full:true”]
[/quote]
That did the trick, how do you set up that hotkey, I like the idea. I see the hotkeys in the Preferences dialog.
Jacob
go to preferences → hotkeys, scroll down to paste special (or search paste special in the filter box at the top), double click on paste special, then press ctrl+shift+v.
