i try to use the 8.0 nightly version to gernerate IPC26581 file and use in ANSYS to do further simualtion.
ANSYS has the error inforamtion as,
*Global - Messages
[error] Control File Translation: IPC2581 file is missing Stackup: Functional mode should be FULL or USERDEF and Stackup must be selected for export.
I opened the gernarated file to check the stackup information, it is in this way:
Our IPC2581 export is in "Functional Mode""ASSEMBLY". This means that we include the data required by the IPC2581 standard for PCB fabrication and assembly.
ANSYS simulation requires additional data, which is why they are looking for the Stackup section. We haven’t included this optional section in the export at this time. You are welcome to request this feature and we’ll look at adding it in the future.
Thanks, but this is not clear to me, and I don’t have access to the standard documentation.
For example, if I go to get a PCB fabricated, I send the Gerber files (layer and drill) along with a stackup file and a set of build notes.
If I use an IPC-2518 file from KiCad, will I need to also send an additional stackup file?
I’m asking for two reasons:
I was under the impression that the IPC-2518 file would include this information. Needing multiple files is a common pain point for us and while our error rate is low, a missing or erroneous build file is a cause of errors, or more frequently, delays for us.
Another reasons we are looking IPC-2518 is that we are beginning to use FEM software, and want to be able import the PCB in as few steps as possible. In Altium, we generate an ODB++ file and read it in. Our goal is to be able to do the same with KiCad.
