IPC-2581 Fabrication Outputs
Hello
IPC-2581 contains data for the board, as well assembly data.
If I order without assembly, the assembly data are not needed.
And then I want to hide the assembly data.
I do not know if IPC-2581 supports omitted assembly data.
If it does, IMHO in the dialog “Fabrication Outputs” there should be an option to omit that.
My question now, is there a way to do that.
btw. I am running 8.0.8
Regards
peter
