I have problems to start KiCad from Ubuntu 16.
Every time I start KiCad by pressing on the icon it appears in the bars and disappear again.
If I start it via terminal by “kicad” the follwowing error appears:
“kicad: error while loading shared libraries: /usr/lib/x86_64-linux-gnu/libwx_gtk2u_aui-3.0.so.0: invalid ELF header”
I noticed same behavior by starting FileZilla
“filezilla: error while loading shared libraries: /usr/lib/x86_64-linux-gnu/libwx_gtk2u_aui-3.0.so.0: invalid ELF header”
Hope anyone can help.
UPDATE :
I cleaned up my PPAs and now I get an other ELF error. Now (by FileZilla and KiCad) I get the follwoing new error:
kicad: error while loading shared libraries: /usr/lib/x86_64-linux-gnu/libwx_baseu_net-3.0.so.0: invalid ELF header
The old error:
Sorry, but this is nonsense.
No library needs executing right. A library is getting loaded and the required symbol needs to be available so it can get loaded and used by the application. In the *nix world they are called Shared Objects (hence the file extension .so), in Windows they are called Dynamic Link Library (aka the .dll suffix).
I hesitate to offer suggestions because frustratingly this is the sort of problem that an experienced Linux user can solve on the spot, but there’s only online communication to you. Also I don’t have an Ubuntu system to hand, as my distro uses RPM so I may make typos in the DEB commands. But I’ll give you some questions to check which might give you a clue.
Has filezilla worked in the past? Did the problem start sometime? Do you remember what you did?
Did you add any repos that aren’t for 16.04? Did you install from the correct KiCad PPA?
What does the command dpkg -S /usr/lib/x86_64-linux-gnu/libwx_gtk2u_aui-3.0.so.0 print out? (Should be name of package that it was installed from.)
Check the file /usr/lib/x86_64-linux-gnu/libwx_gtk2u_aui-3.0.so.0. This is probably a symlink to …so.0.2 if the info on this package is correct. Is the …so.0.2 file there? Does it look whole or too small? (Should be a few hundred kB as that’s the size on my system.) What does the utility “file” say about it?
What does ldd /usr/bin/kicad | grep libwx print out? Ditto for filezilla. Missing dynamic library is a problem.
Is it possible you have disk errors on your system that might corrupt files?
UPDATE: I cleaned up my PPAs and now I get an other ELF error. Now (by FileZilla and KiCad) I get the follwoing error:
The old error:
is not available anymore.
FileZilla and KiCad worked in the past without problems. I think I installed some nasty software in the past…
It is possible that I add in the past by mistake some wrong repos which aren’t for 16.04. Yes, I think I installed it correctly because it works fine in the past.
I get the following output:
Yes, in the past I had a disk error and my computer didn’t start. I had to start the computer by recovery mode. It fixed something on the disk for a while and the computer started.
My output from the same command is
lrwxrwxrwx 1 root root 28 Jan 2 2019 /usr/lib/x86_64-linux-gnu/libwx_gtk2u_aui-3.0.so.0 -> libwx_gtk2u_aui-3.0.so.0.4.0
-rw-r–r-- 1 root root 624744 Jan 2 2019 /usr/lib/x86_64-linux-gnu/libwx_gtk2u_aui-3.0.so.0.4.0
am using Version: 5.1.9+dfsg1-1~bpo10+1, release build
