I figure I’d start a new topic (instead of “hijacking” the related thread Odd behaviour when making a "large pad / zone" out of traces).
Looking at the zone’s representation in the .kicad_pcb
file, there is polygon
, and there is filled_polygon
What exactly is filled_polygon
? I figured it would be the polygon representing the “rendered” actual filled zone, taking into account the corner smoothing that one indicates (and clearances, I guess?). But the corners don’t really match. Even more strangely, I set the corner smoothing to None
, and then the filled_polygon
has the same number of vertices as the polygon
— but they are not the same points (so, what’s up with that!). Example:
(polygon
(pts
(xy 30.36 32.31) (xy 46.11 32.31) (xy 46.11 43.61) (xy 30.36 43.61)
(filled_polygon
(pts
(xy 45.983 43.483) (xy 30.487 43.483) (xy 30.487 32.437) (xy 45.983 32.437)
How would I go about changing the coordinates of the polygon’s vertices? (you know, as a workaround for the lack of “Properties” dialog to manually edit the positions of a zone’s corners) Is it safe to just change the coordinates of the polygon
part? (then re-open the file in KiCAD and let pcbnew recalculate the filled_polygon
Thanks
