Elsewhere someone said it would work with raytracing but it looks like the interior cut is
somehow too shallow. The board edge looks OK and it does seem to cut something. I did play
around and saw that the holes are rendered with realism turned off. Also it works if I turn off
show filled areas. So at least I can see that the cuts are there.
What Kicad version?
I’ve built boards with cut outs that remove material from all layers, within a solid pcb outline.
You are implying that you want to remove material from ONLY a buried layer. It would help if you define what you want to achieve.
5.1.10 but i have a fresh copy to try
im just doing a cutout, a hole you can see through,
i found workarounds as i mentioned
ill delete the post if its fixed in the one i just downloaded
I don’t think the 3d viewer shows the interior cuts. You should look with the Gerber viewer and you should see it ok.
Please don’t delete original posts unless they are totally inappropriate.
Version 5.1.11 on Linux shows interior cuts.
Make sure the cutout is a continuous line without gaps or crossings.
@ringo458 please describe what exact steps did you perform.
How do you draw your “interior cut”, and if you have rebuilt copper zones afterwards.
As @eelik says, PCB routed openings are displayed correctly in the 3d viewer.
Also, does it happen to you only in Raytracing or also in a regular 3d view?
I draw an internal cut on a board and used the 3d view to check it out:
cutout:
3d view (standard):
3d view (raytracing):
How ever, after I update my zones with ‘B’:
All seems as expected:
Application: Pcbnew
Version: (5.1.10)-1, release build
wxWidgets 3.0.5
libcurl/7.71.0 OpenSSL/1.1.1g (Schannel) zlib/1.2.11 brotli/1.0.7 libidn2/2.3.0 libpsl/0.21.0 (+libidn2/2.3.0) libssh2/1.9.0 nghttp2/1.41.0
wxWidgets: 3.0.5 (wchar_t,wx containers,compatible with 2.8)
Boost: 1.73.0
Curl: 7.71.0
Compiler: GCC 10.2.0 with C++ ABI 1014
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
Working nicely on Windows with what will be 5.1.11
