One can ADD a power port by using the “a” HotKey. And then ALL the normal properties are allowed to be edited
Select the FIELD value, for a part that is just a visual display, then run the ERC with errors.
I was trying to figure out what exactly was wrong, but I got lost in my process; sorry about that.
Essentially, as I understand the issue at the moment, the DRC does not like power symbols added with the HotKeys with “a” selected as the HotKey, which then allows assignment of a footprint to a part that does not actually exist.
Any and all Power Symbols should have the footprint select field disabled in my opinion.
I’m sorry that I could not nail the actual operation of failed events any better.
Just a clarification:
It’s the other way round. The pin name determines the resulting net name. (The value and symbol name should be the same so that the user of the symbol knows what they get.)
Disallowing this is reasonable to me; I may propose it on the mailing list. Power components do not get exported to the PCB anyway so there is little use in assigning a footprint even if someone had come up with a contrived workflow where it might make “sense”
