Using Kicad 7.0.6 on Mac 13.4.1 (And wIndows 10, tried both).
When trying to place a via, the via will never shove a trace on another layer, is there a way to enable that feature or tweak it? I believe this was possible in version 5 but not for sure.
I also gave it a try yesterday, and it seemed to work on my 2 layer board.
According to the gitlab link though, the problem only manifests itself on multi layer boards and I did not test that. Did you test it on a multilayer?
So you admit you’ve become addicted to the Interactive Router?
A common cause for that stress is packing your footprints too close together. Beyond a certain footprint density, getting the board routed becomes explosively difficult. I’m also the venn diagram with routing small PCB’s intensively and the interactive router has dared me to make my boards just that little bit smaller then I would have even dared to attempt without it.
When I look at it objectively, the extra work for that last cm is just insane, but that is what addicted people do.
The following version works on Windows, will try to update to the latest nightly and see if its the same. Also checked 7.0.7RC1 and it works. Any reason why mac doesn’t work?
