I’ve just been playing around with @qu1ck 's amazing Interactive HTML BOM plugin in KiCad v5.99 (https://github.com/openscopeproject/InteractiveHtmlBom). It works really well and I really like the fact that I can generate a netlist in the schematic and have all the component fields available to be shown.
However, I haven’t been able to figure out how to add the component “Description” as shown in the library. Has someone been able to do this successfully?
Description is not a part field, it’s a component field, in other words its immutable for component instance placed on schematic and is inherited from library component.
That’s why it’s not supported right now but a feature can be added as optional extra field in ibom.
However the method of parsing .net or .xml files for schematic fields will be deprecated soon since kicad 6 has schematic fields are imported into pcb data. Description isn’t imported though. I’ll see if kicad folks are open to importing that as well.
Thanks for the @qu1ck reply! I will thumbs up your issue for v7.
In the meantime might it be possible to use the legacy netlist file for this? I just had a look and it seems that the description field is transferred via the libsource token:
Yes, the data is there so it’s possible, like I said. But I’m reluctant to add it if equivalent feature will not be available in v6 and I want to move away from parsing netlist file.
Ok I think I understand where you are coming from in terms of plugin maintenance. I have managed to get it working by editing the netlist parser. (By the way Kudos for the simplicity of the plugin: it does make it very easy to add to it!)
For the benefit of others reading this thread, I have been able to get this to work with some small changes to the file InteractiveHtmlBom/ecad/kicad_extra/netlistparser.py. The diff is below, as well as the full file attached for those not using git. All you need to do is replace the file and reload the plugin.
InteractiveHtmlBom/ecad/kicad_extra/netlistparser.py | 8 ++++++++
1 file changed, 8 insertions(+)
diff --git a/InteractiveHtmlBom/ecad/kicad_extra/netlistparser.py b/InteractiveHtmlBom/ecad/kicad_extra/netlistparser.py
index 724673b..d1c395b 100644
--- a/InteractiveHtmlBom/ecad/kicad_extra/netlistparser.py
+++ b/InteractiveHtmlBom/ecad/kicad_extra/netlistparser.py
@@ -20,6 +20,7 @@ class NetlistParser(ParserBase):
ref = None
fields = None
datasheet = None
+ libsource = None
for f in c[1:]:
if f[0] == 'ref':
ref = f[1]
@@ -27,12 +28,19 @@ class NetlistParser(ParserBase):
fields = f[1:]
if f[0] == 'datasheet':
datasheet = f[1]
+ if f[0] == 'libsource':
+ libsource = f[1:]
if ref is None:
return None
ref_fields = comp_dict.setdefault(ref, {})
if datasheet and datasheet != '~':
field_set.add('datasheet')
ref_fields['datasheet'] = datasheet
+ if libsource is not None:
+ for libField in libsource:
+ if libField[0] == 'description':
+ field_set.add('Description')
+ ref_fields['Description'] = libField[1]
if fields is None:
continue
for f in fields:
I looked at your diff and realized that I already have custom logic for datasheet field which is also not transferred to pcb. So my reasoning is moot and I probably am stuck with parsing netlist either way.
