fred4u
October 21, 2023, 4:59pm
1
Hello KiCad fans,
On today fresh 7.0.8 testing (Version: 7.0.8-84-geb7929ccb6), just installed Interactive BOM plugin, and when using the plugin, I get the error upon Generate BOM:
Type error: GetEffectiveTextShape() got an unexpected keyword argument ‘aTriangulate’.
Anyone expected similar issue?
qu1ck
October 21, 2023, 9:11pm
2
Already fixed
opened 02:59PM - 09 Oct 23 UTC
closed 08:00PM - 09 Oct 23 UTC
I got the following Error:
my Kicad Version:
Version: 7.0.8-56-g9260f58803, release build
wxWidgets 3.2.2
FreeType 2.12.1
HarfBuzz 6.0.0
FontConfig 2.14.1
libcurl/7.88.1-DEV Schannel zlib/1.2.13
Date: Oct 7 2023 05:13:57
wxWidgets: 3.2.2 (wchar_t,wx containers)
Boost: 1.81.0
OCC: 7.7.1
Curl: 7.88.1-DEV
ngspice: 41
KICAD_SPICE=ON
The design I can not share.
I will try to reproduce it with a simple project.
I will issue new release closer to when 7.0.9 will land.
Kilted
November 1, 2023, 2:45pm
3
Hi. I get an error when trying to install from the Plugin and Content Manager. I’m also on 7.0.8:
Downloading package url: 'https://github.com/openscopeproject/InteractiveHtmlBom/releases/download/v2.8.0/InteractiveHtmlBom_v2.8.0_pcm.zip'
Extracting package 'org.openscopeproject.InteractiveHtmlBom'.
Error extracting file!
Removing downloaded archive 'org.openscopeproject.InteractiveHtmlBom_v2.8.0.zip'.
Done.
Any ideas please?
qu1ck
November 1, 2023, 3:11pm
4
Do you see this error only for this plugin? Can you try installing anything else?
You can also try installing from file directly https://github.com/openscopeproject/InteractiveHtmlBom/releases/download/v2.8.0/InteractiveHtmlBom_v2.8.0_pcm.zip
Use “isntall from file…” button in plugin manager.
Kilted
November 1, 2023, 3:44pm
5
Hi @qu1ck , nothing happens when I try to install from file. Something flashes up and then disappears.
I’ve since discovered I can’t install any plugins.
I saw one of your comments on another forum post where you talk about permissions. When I click ‘Open Package Directory’ nothing happens. Is there a setting somewhere to specify the installation folder? I do have full rights to my machine - Windows 10.
qu1ck
November 1, 2023, 5:02pm
6
In Kicad main window Preferences -> Configure Paths...
menu and set KICAD7_3RD_PARTY path to somewhere you can write.
system
Closed
January 30, 2024, 5:03pm
7
