I just want to start using KiCAD. So I followed the instructions online to install it on my Ubuntu machine. After running the installation command, it says that 12 GB of stuff will be installed. Is this normal?
I got the following:
sudo apt install --install-suggests kicad
Reading package lists… Done
Building dependency tree
Reading state information… Done
The following additional packages will be installed:
ant ant-doc ant-optional antlr antlr3 antlr3.2 apache2 apache2-bin apache2-data apache2-doc
apache2-suexec-pristine apache2-utils auctex autoconf autoconf-archive autoconf-doc automake
autopoint autotools-dev bsh bsh-doc bundler catdvi chktex cl-asdf cl-launch cl-swank clisp
clisp-dev clisp-doc cm-super cm-super-minimal cup dbtoepub debhelper debiandoc-sgml
debiandoc-sgml-doc default-jdk default-jdk-doc default-jdk-headless dh-autoreconf dh-make
dh-strip-nondeterminism doc-base docbook docbook-defguide docbook-dsssl docbook-dsssl-doc
docbook-mathml docbook-xml docbook-xsl docbook-xsl-doc-html docbook-xsl-saxon dot2tex dvidvi
dvipng dwz emacs25 emacs25-bin-common emacs25-common emacs25-common-non-dfsg emacs25-el
extra-xdg-menus feynmf fig2dev fontforge fontforge-common fontforge-doc fontforge-extras
fonts-adf-accanthis fonts-adf-berenis fonts-adf-gillius fonts-adf-universalis
fonts-arphic-bkai00mp fonts-arphic-bsmi00lp fonts-arphic-gbsn00lp fonts-arphic-gkai00mp
fonts-baekmuk fonts-cabin fonts-cantarell fonts-comfortaa fonts-croscore fonts-ebgaramond
fonts-ebgaramond-extra fonts-font-awesome fonts-freefont-otf fonts-gfs-artemisia
fonts-gfs-baskerville fonts-gfs-complutum fonts-gfs-didot fonts-gfs-neohellenic fonts-gfs-olga
fonts-gfs-porson fonts-gfs-solomos fonts-go fonts-hosny-amiri fonts-inconsolata
fonts-ipaexfont-gothic fonts-ipaexfont-mincho fonts-ipafont-gothic fonts-ipafont-mincho
fonts-junicode fonts-lato fonts-lmodern fonts-lobster fonts-lobstertwo fonts-mathjax
fonts-mathjax-extras fonts-noto-hinted fonts-oflb-asana-math fonts-open-sans fonts-roboto-hinted
fonts-sil-gentiumplus fonts-sil-gentiumplus-compact fonts-stix fonts-texgyre fonts-unfonts-core
fonts-unfonts-extra fop fop-doc fragmaster gawk gawk-doc gcc-7-multilib gcc-multilib
geoip-database-extra gfortran gfortran-7 gfortran-7-doc gfortran-7-multilib gfortran-doc
gfortran-multilib glew-utils gmp-doc gnu-standards graphviz graphviz-doc groff gsfonts-x11
hyperspec iamerican ibverbs-providers icc-profiles icc-profiles-free ienglish-common ispell
java-wrappers javacc javacc-doc javahelp2 javahelp2-doc javascript-common jlex junit junit-doc
junit4 jython jython-doc kicad-demos kicad-doc-en kicad-footprints kicad-libraries
kicad-locale-ko kicad-packages3d kicad-symbols kicad-templates lacheck latex-cjk-all
latex-cjk-chinese latex-cjk-chinese-arphic-bkai00mp latex-cjk-chinese-arphic-bsmi00lp
latex-cjk-chinese-arphic-gbsn00lp latex-cjk-chinese-arphic-gkai00mp latex-cjk-common
latex-cjk-japanese latex-cjk-japanese-wadalab latex-cjk-korean latex-cjk-thai latexdiff latexmk
lib32asan4 lib32atomic1 lib32cilkrts5 lib32gcc-7-dev lib32gcc1 lib32gfortran-7-dev lib32gfortran4
lib32gomp1 lib32itm1 lib32mpx2 lib32quadmath0 lib32stdc++6 lib32ubsan0 libactivation-java libann0
libantlr-java libantlr3-runtime-java libapr1 libaprutil1 libaprutil1-dbd-sqlite3 libaprutil1-ldap
libarchive-cpio-perl libasm-java libatinject-jsr330-api-java libatinject-jsr330-api-java-doc
libavalon-framework-java libavalon-framework-java-doc libb-hooks-op-check-perl libbatik-java
libbcel-java libbcel-java-doc libbcpkix-java libbcpkix-java-doc libbcprov-java libbcprov-java-doc
libbit-vector-perl libbsf-java libc-ares2 libc6-dev-i386 libc6-dev-x32 libc6-i386 libc6-x32
libcaf-mpi2 libcarp-clan-perl libcdt5 libcgraph6 libclass-method-modifiers-perl libcoarrays-dev
libcommon-sense-perl libcommons-codec-java libcommons-compress-java libcommons-csv-java
libcommons-io-java libcommons-io-java-doc libcommons-net-java libcommons-net-java-doc
libcompress-lzf-java libconversant-disruptor-java libconvert-binhex-perl
libcrypt-openssl-bignum-perl libcrypt-openssl-rsa-perl libcrypt-rc4-perl libcudart9.1 libcurl4
libdate-calc-perl libdate-calc-xs-perl libdate-manip-perl libdbi-perl libdevel-callchecker-perl
libdevel-globaldestruction-perl libdigest-perl-md5-perl libdisruptor-java libdom4j-java
libdom4j-java-doc libdynaloader-functions-perl libemail-date-format-perl libemail-simple-perl
libemf1 libencode-detect-perl libencode-hanextra-perl libequinox-osgi-java libev-perl libfabric1
libfelix-framework-java libfelix-framework-java-doc libfelix-main-java libfelix-main-java-doc
libffcall1b libfile-homedir-perl libfile-remove-perl libfile-stripnondeterminism-perl
libfile-which-perl libfontbox-java libfontforge2 libfop-java libfreeimage3 libfreezethaw-perl
libgcc1-dbg libgdraw5 libgeo-ip-perl libgeronimo-jms-1.1-spec-java libgfortran-7-dev
libgfortran4-dbg libgl2ps1.4 libglew2.0 libgmp-dev libgmp10-doc libgmpxx4ldbl libgoogle-gson-java
libgoogle-gson-java-doc libgts-0.7-5 libgts-bin libguava-java libgvc6 libgvpr2 libhamcrest-java
libhawtjni-runtime-java libhttp-parser2.7.1 libhttpclient-java libhttpcore-java
libhwloc-contrib-plugins libhwloc-plugins libhwloc5 libibverbs1 libice-dev libice-doc
libicu4j-java libintellij-annotations-java libintellij-annotations-java-doc
libio-socket-socks-perl libio-stringy-perl libisorelax-java libjackson2-annotations-java
libjackson2-annotations-java-doc libjackson2-core-java libjackson2-core-java-doc
libjackson2-databind-java libjackson2-databind-java-doc libjackson2-dataformat-xml-java
libjackson2-dataformat-xml-java-doc libjackson2-dataformat-yaml libjackson2-dataformat-yaml-doc
libjackson2-module-jaxb-annotations-java libjansi-java libjansi-native-java libjaxb-api-java
libjaxen-java libjaxp1.3-java libjcode-pm-perl libjcommander-java libjcommander-java-doc
libjctools-java libjdepend-java libjdom1-java libjdom1-java-doc libjeromq-java libjffi-java
libjffi-jni libjline-java libjline-java-doc libjline2-java libjna-java libjna-java-doc libjna-jni
libjna-platform-java libjnr-constants-java libjnr-ffi-java libjnr-ffi-java-doc libjnr-netdb-java
libjnr-netdb-java-doc libjnr-posix-java libjnr-posix-java-doc libjnr-x86asm-java
libjpa-2.1-spec-java libjs-jquery libjs-jquery-mousewheel libjs-jquery-ui libjs-jquery-ui-docs
libjs-mathjax libjs-mathjax-doc libjs-modernizr libjs-prettify libjs-sphinxdoc libjs-underscore
libjsch-java libjsr305-java libjsr305-java-doc libjxr0 libjzlib-java
libknopflerfish-osgi-framework-java liblab-gamut1 liblightcouch-java liblockfile-bin liblockfile1
liblog4j1.2-java liblog4j1.2-java-doc liblog4j2-java liblog4j2-java-doc libltdl-dev liblua5.2-0
libm17n-0 libmagick+±6.q16-7 libmail-box-perl libmail-dkim-perl libmail-java libmail-java-doc
libmail-message-perl libmail-sendmail-perl libmail-spf-perl libmail-transport-perl
libmath-base-convert-perl libmime-charset-perl libmime-tools-perl libmime-types-perl
libmldbm-perl libmodule-runtime-perl libmojo-server-fastcgi-perl libmojolicious-perl
libmongodb-java libmpfr-dev libmpfr-doc libmsv-java libmysql-java libnb-org-openide-modules-java
libnb-org-openide-util-java libnb-org-openide-util-lookup-java libnb-platform18-java
libnet-cidr-lite-perl libnet-daemon-perl libnet-patricia-perl libnetaddr-ip-perl libnetty-java
libngspice-kicad libnl-route-3-200 libnvidia-compute-430 libobject-realize-later-perl
liboce-foundation11 liboce-modeling11 liboce-ocaf-lite11 liboce-ocaf11 liboce-visualization11
libole-storage-lite-perl libopenmpi2 liboro-java libosgi-annotation-java
libosgi-annotation-java-doc libosgi-compendium-java libosgi-compendium-java-doc libosgi-core-java
libosgi-core-java-doc libosp5 libostyle1c2 libotf0 libparams-classify-perl libparams-util-perl
libparse-recdescent-perl libpathplan4 libplot2c2 libpod2-base-perl libpoppler-qt5-1
libpostgresql-jdbc-java libpotrace0 libprotobuf-java libpsm-infinipath1 libpstoedit0c2a
libptexenc1 librarian0 librdmacm1 libregexp-java librelaxng-datatype-java librhino-java
librhino-java-doc librole-tiny-perl libroman-perl libruby2.5 libsaxon-java libsaxon-java-doc
libsaxonhe-java libsgmls-perl libsigsegv2 libslf4j-java libsm-dev libsm-doc libsombok3 libspiro0
libspreadsheet-parseexcel-perl libspreadsheet-writeexcel-perl libsql-statement-perl
libstax2-api-java libstringtemplate-java libstringtemplate4-java libsub-exporter-progressive-perl
libswing-layout-java libswing-layout-java-doc libsynctex1 libsys-hostname-long-perl libtcl8.6
libtexlua52 libtexluajit2 libtext-autoformat-perl libtext-format-perl libtext-reform-perl
libtext-soundex-perl libtext-unidecode-perl libtk8.6 libtool libtool-doc
libunicode-linebreak-perl libunicode-map-perl libuninameslist1 libuser-identity-perl libutempter0
libuuid-perl libuv1 libvisualvm-jni libwoodstox-java libwxbase3.0-0v5 libwxgtk3.0-gtk3-0v5
libx32asan4 libx32atomic1 libx32cilkrts5 libx32gcc-7-dev libx32gcc1 libx32gfortran-7-dev
libx32gfortran4 libx32gomp1 libx32itm1 libx32quadmath0 libx32stdc++6 libx32ubsan0 libxalan-c111
libxalan2-java libxalan2-java-doc libxerces-c3.2 libxerces2-java libxerces2-java-doc
libxml-commons-external-java libxml-commons-resolver1.1-java libxml-commons-resolver1.1-java-doc
libxml2-utils libxmlgraphics-commons-java libxmlgraphics-commons-java-doc libxnvctrl0 libxom-java
libxom-java-doc libxpp2-java libxpp3-java libxsltc-java libxslthl-java libxt-dev libxt-doc
libxz-java libyaml-snake-java libyaml-snake-java-doc libyaml-tiny-perl libzip4 libzzip-0-13
linuxdoc-tools linuxdoc-tools-info linuxdoc-tools-latex linuxdoc-tools-text lmodern m17n-db
m17n-docs m4 m4-doc mpi-default-bin ncurses-term node-requirejs nodejs nodejs-doc openjade
openjdk-11-demo openjdk-11-doc openjdk-11-jdk openjdk-11-jdk-headless openjdk-11-source
openmpi-bin openmpi-common opensp perl-tk pfb2t1c2pfb po-debconf potrace prerex
preview-latex-style ps2eps psgml pstoedit psutils purifyeps python-chardet python-fontforge
python-pygments python-pyparsing python-pyparsing-doc python3-sip python3-wxgtk4.0 pyzor
pyzor-doc rake rarian-compat razor re2c rhino ri ruby ruby-bundler ruby-dev ruby-did-you-mean
ruby-minitest ruby-molinillo ruby-net-http-persistent ruby-net-telnet ruby-power-assert
ruby-test-unit ruby-thor ruby2.5 ruby2.5-dev ruby2.5-doc rubygems-integration sa-compile sbcl
sbcl-doc sbcl-source sgml-base sgml-base-doc sgml-data sgmls-doc sgmlspl slime spamassassin spamc
spell sphinx-rtd-theme-common tcl tcl-tclreadline tcl8.6 testng tex-common tex-gyre texinfo
texinfo-doc-nonfree texlive texlive-base texlive-binaries texlive-extra-utils texlive-font-utils
texlive-fonts-extra texlive-fonts-extra-doc texlive-fonts-extra-links texlive-fonts-recommended
texlive-fonts-recommended-doc texlive-formats-extra texlive-generic-recommended texlive-lang-all
texlive-lang-arabic texlive-lang-chinese texlive-lang-cjk texlive-lang-cyrillic
texlive-lang-czechslovak texlive-lang-english texlive-lang-european texlive-lang-french
texlive-lang-german texlive-lang-greek texlive-lang-italian texlive-lang-japanese
texlive-lang-korean texlive-lang-other texlive-lang-polish texlive-lang-portuguese
texlive-lang-spanish texlive-latex-base texlive-latex-base-doc texlive-latex-extra
texlive-latex-extra-doc texlive-latex-recommended texlive-latex-recommended-doc texlive-luatex
texlive-metapost texlive-metapost-doc texlive-pictures texlive-pictures-doc texlive-plain-generic
texlive-pstricks texlive-pstricks-doc texlive-xetex tipa tk tk8.6 ttf-bitstream-vera visualvm
vprerex w3-dtd-mathml w3-recs wx3.0-doc xalan xaw3dg xbitmaps xfig xfig-doc xfig-libs
xfonts-cyrillic xindy xindy-rules xml-core xsltproc xterm
Suggested packages:
autotrace kicad-libraries kicad-doc-ko hbf-cns40-b5 hbf-jfs56 hbf-kanji48
libning-compress-lzf-java-doc libscalar-number-perl gcj-jdk doc-html-w3 w3c-dtd-xhtml perlsgml
ruby-tcltk | libtcltk-ruby
The following packages will be REMOVED:
libcurl3
The following NEW packages will be installed:
junit4 jython jython-doc kicad kicad-demos kicad-doc-en kicad-footprints kicad-libraries
0 upgraded, 690 newly installed, 1 to remove and 0 not upgraded.
Need to get 3,227 MB of archives.
After this operation, 12.3 GB of additional disk space will be used.
