Was following the HOW_TO_CONTRIBUTE.txt guide and hit this: (From Git)
kevin@debian:~$ sudo apt-get install libwxbase2.8-dev libwxgtk2.8-dev libboost-dev fakeroot
Reading package lists… Done
Building dependency tree
Reading state information… Done
E: Unable to locate package libwxbase2.8-dev
E: Couldn’t find any package by regex ‘libwxbase2.8-dev’
E: Unable to locate package libwxgtk2.8-dev
E: Couldn’t find any package by regex ‘libwxgtk2.8-dev’
Cure?
sudo apt-get install libwxbase3.0-dev libwxgtk3.0-dev libboost-dev fakeroot
fakeroot is already the newest version.
fakeroot set to manually installed.
The following extra packages will be installed:
libboost1.55-dev wx-common wx3.0-headers
Suggested packages:
libboost-doc libboost1.55-doc libboost-atomic1.55-dev
libboost-chrono1.55-dev libboost-context1.55-dev libboost-coroutine1.55-dev
libboost-date-time1.55-dev libboost-exception1.55-dev
libboost-filesystem1.55-dev libboost-graph1.55-dev
libboost-graph-parallel1.55-dev libboost-iostreams1.55-dev
libboost-locale1.55-dev libboost-log1.55-dev libboost-math1.55-dev
libboost-mpi1.55-dev libboost-mpi-python1.55-dev
libboost-program-options1.55-dev libboost-python1.55-dev
libboost-random1.55-dev libboost-regex1.55-dev
libboost-serialization1.55-dev libboost-signals1.55-dev
libboost-system1.55-dev libboost-test1.55-dev libboost-thread1.55-dev
libboost-timer1.55-dev libboost-wave1.55-dev libboost1.55-tools-dev
libmpfrc+±dev libntl-dev wx3.0-doc
The following NEW packages will be installed:
libboost-dev libboost1.55-dev libwxbase3.0-dev libwxgtk3.0-dev wx-common
wx3.0-headers
Debian Jessie.
More:
– Check for installed GLEW – not found
CMake Error at CMakeModules/CheckFindPackageResult.cmake:6 (message):
GLEW was not found - it is required to build Kicad
Call Stack (most recent call first):
CMakeLists.txt:454 (check_find_package_result)
– Configuring incomplete, errors occurred!
See also “/home/kevin/kicad.my_contrib/build/CMakeFiles/CMakeOutput.log”.
Fix:
kevin@debian:~/kicad.my_contrib/build$ sudo apt-get install libglew-dev
libglew-dev
0 upgraded, 1 newly installed, 0 to remove and 2 not upgraded.
Need to get 114 kB of archives.
After this operation, 1,113 kB of additional disk space will be used.
Get:1 http://mirrors.xmission.com/debian/ jessie/main libglew-dev amd64 1.10.0-3 [114 kB]
Fetched 114 kB in 0s (707 kB/s)
Selecting previously unselected package libglew-dev:amd64.
(Reading database … 264524 files and directories currently installed.)
Preparing to unpack …/libglew-dev_1.10.0-3_amd64.deb …
Unpacking libglew-dev:amd64 (1.10.0-3) …
Setting up libglew-dev:amd64 (1.10.0-3) …
Died:
kevin@debian:~/kicad.my_contrib/build$ cmake …/ -DCMAKE_BUILD_TYPE=Debug
– Kicad install dir: </usr/local>
– Check for installed OpenGL – found
– Found Glew: /usr/lib/x86_64-linux-gnu/libGLEW.so
– Check for installed GLEW – found
– checking for module ‘cairo’
– package ‘cairo’ not found
– Could NOT find CAIRO, try to set the path to CAIRO root folder in the system variable CAIRO (missing: CAIRO_LIBRARIES CAIRO_INCLUDE_DIR)
– Check for installed Cairo – not found
Cairo was not found - it is required to build Kicad
CMakeLists.txt:463 (check_find_package_result)
Tried:
kevin@debian:~/kicad.my_contrib/build$ sudo apt-get install libcairo2
libcairo2 is already the newest version.
libcairo2 set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
same results - it was already installed.
Could someone take a look at the HOW_TO_CONTRIBUTE file and add what is missing?
Beating this to completion with time isn’t a solution.
