Hi there,
I am trying to learn electronics with KiCad. I am working on a project, where I am trying to control a readily existing board with my own circuit. I would like to design this existing board in KiCad and import as a component, which means that I would like to design inner routings, a capacitor and a resistor inside this board + the pins available. Luckily the board is very simple. But I can’t figure out how to add wirings, components in the library editor. Do I need to add a separate schematic to my project?
Please feel free to correct my phrasing or vocabulary, if my message doesn’t make sense. I am a beginner without formal education in electronics.
It is a bit unclear though what you really want.
If you have an existing board (For example an ESP8266 module) which can be represented by a single physical object (Footprint) on the pcb, then you want to want to create it as a schematic symbol.
If you have some sub assembly, For example a SMPS circuit which consists of an IC, some resistors and capacitors, but you want a single schematic symbol in EEschem to represent it. Then you want to use the Hierarchical sheet stuff in EEschem.
Thanks paulvdh! That seems to be exactly what I wanted to do. My logic was, “let’s observe that board as a component”. But since I know the schematics by looking at it, I wanted to make a “detailed” component schematic, which I can also add to the library.
