Incorrect bus alias conflicting definition error message
ERC gives:
but only bus aliases CB23 and CB24 appear on the Trackside bell JB sheet (not CB18) as here:
What should I do?
Z
Sidings-2025-01-30_102023.zip (145.4 KB)
ip file attached.
Application: KiCad Schematic Editor x64 on x64
Version: 8.0.1, release build
wxWidgets 3.2.4
FreeType 2.12.1
HarfBuzz 8.3.0
FontConfig 2.14.2
Date: Mar 15 2024 01:52:47
Boost: 1.83.0
OCC: 7.7.1
Curl: 8.5.0-DEV
ngspice: 42
ersion Info
wxWidgets 3.2.4
FreeType 2.12.1
HarfBuzz 8.3.0
FontConfig 2.14.2
Boost: 1.83.0
OCC: 7.7.1
Curl: 8.5.0-DEV
ngspice: 42
BTW do upgrade ot the latest 8.0.x, it will not affect your configuration and may fix bugs.
Start from upgrading to latest V8 version.
I moved from V7 to V8 when V8 reached 8.0.3, so I have never used 8.0.1. It is because typically first new main version releases have many bugs. Each last digit version number change means several dozen bugs fixed.
What should I do?
After you are finished with upgrading you should put on a record and listen to your favorit music. Afterwards you open kicad schematic–>File–>Schematic Setup–>project–>bus alias definitions and carefully look through the “Alias” column. You will find two rows with different definitions for “CB18”. Delete one.
PS: very helpful to attach the project directly in your opening post! (imagine thumbs up icon here)
Blockquote
Blockquote
That does it! Why didn’t I tink of looking there.
Many thanks
Is this the place to ask for the ERC to check for duplicate alias names?
