I try to write a script which generates a PDF, SVG or similar from the PCB which includes the title block. As far as i understand, i can set this with SetPlotFrameRef(True)
. But then i get the error /build/kicad-UH8AyZ/kicad-5.1.5+dfsg1/pcbnew/pcbnew.cpp(218): assert "process" failed in Pgm().
in OpenPlotfile(...)
and a segmentation fault. It works when i change it to SetPlotFrameRef(False)
, but then i don’t have a title block.
Is SetPlotFrameRef(True)
the correct way to include the title block in a plot?
Is there a way to avoid the segmentation fault?
How does pcbnew know which kicad_wks file to use? I know that this is not stored in the kicad_pcb file. Do i need to set it somehow first?
A simple version of my script:
#!/usr/bin/python3
import pcbnew
import sys
layers=[[ "F.Cu", "cu_top" ]]
def debug(n):
sys.stderr.write("DEBUG "+str(n)+"\n")
def plot(input,outPath,format=pcbnew.PLOT_FORMAT_PDF):
controller=pcbnew.PLOT_CONTROLLER(input)
options=controller.GetPlotOptions()
options.SetFormat(format)
options.SetPlotFrameRef(True) #It works without this
options.SetOutputDirectory(outPath)
for layer in layers:
controller.SetLayer(input.GetLayerID(layer[0]))
debug(0)
controller.OpenPlotfile(layer[1],format,layer[1])
debug(1)
controller.PlotLayer()
input=pcbnew.LoadBoard("<path/to/pcb/file.kicad_pcb>")
#did try to add title block ,didn't work
#input.SetTitleBlock(pcbnew.TITLE_BLOCK())
plot(input,".")
