I can’t find a solution to have the fiducial position included in the .pos file. I’m using version 5.1.0-0
Any solutions for this issue? Thanks!
Edit: I actually can include certain fiducial footprints and others not, is it anything to do with the library? It’s a big problem I have 80+ designs here with 4 fiducials each, so any manual editing solution for each fiducial is a big pain.
That works, thanks Seth_h! Is there any way this can be overridden or globally set or similar, as I have rather a lot of designs to go through and setting this for every fiducial is very annoying?
Maybe we should add that this assumes you have the footprint in a personal library. If you change a footprint supplied with kicad inside the original library then your change will be overwritten on the next update. (or you lock yourself into the current library version.)
