I am not able to delete a single track. I tried every possible method like hovering, then delete, left click, then delete, right click, then delete. I also tried these all in routing mode too. Please help me!!!
A single whole track or track segment ? when you click the track segment is it highlighted ? you can select a segment then use the U hotkey to select the whole track, then delete.
If the track segment isn’t highlighting do you have the Selection filter set to allow you to select tracks ?
And finally . . . . we need to know what Version of KiCad you are using . . . please.
Can you paste your full version info here please, you can get it from KiCad > Help > About KiCad > Copy Version Info
Thank you very much!!!
Problem Solved!!!
