Hello everyone,
I just started designing with kicad6 and I would like to ask, in Kicad 6.0.5. Does “Component Type” in “Footprint Properties → Fabrication Attributes” affect layout design or actual manufacturing?
Because after I imported the model downloaded from “Ultra Librarian”, the default “Component Type” for one SMD component showed as “Through Hole”. Should I change it to SMD?
Also, if a component has properties for both through-hole and SMD, should I set the component type to through-hole?
Best regards,
Will
