Importing via bitmap2component
Can anybody tell me what’s wrong with this footprint?
(module BTant (layer F.Cu) (tedit 5711FA7D)
(fp_text reference A* (at -1.36 2.25) (layer F.SilkS) hide
(effects (font (thickness 0.3)))
(fp_text value BTant (at 3.23 2.35) (layer F.SilkS) hide
(fp_poly (pts (xy -2.032 0.508) (xy 0 0.508) (xy 0 -2.116667) (xy 2.624667 -2.116667)
(xy 2.624667 0.508) (xy 4.656667 0.508) (xy 4.656667 -2.116667) (xy 7.366 -2.116667)
(xy 7.366 2.286) (xy 6.858 2.286) (xy 6.858 -1.608667) (xy 5.164667 -1.608667)
(xy 5.164667 1.016) (xy 2.201334 1.016) (xy 2.201334 -1.608667) (xy 0.423334 -1.608667)
(xy 0.423334 1.016) (xy -2.54 1.016) (xy -2.54 -1.608667) (xy -4.233333 -1.608667)
(xy -4.233333 3.302) (xy -4.741333 3.302) (xy -4.741333 -1.608667) (xy -6.180666 -1.608667)
(xy -6.180666 3.302) (xy -7.027333 3.302) (xy -7.027333 -2.116667) (xy -2.032 -2.116667)
(xy -2.032 0.508)) (layer F.Cu) (width 0.01))
(pad 2 smd rect (at -4.49 3.54) (size 0.5 0.5) (layers F.Cu F.Paste F.Mask))
(pad 1 smd rect (at -6.62 3.54) (size 0.5 0.5) (layers F.Cu F.Paste F.Mask))
What should be wrong with it?
I’m getting an error, when running Cvpcb, when trying to use this footprint
"Errors were encountered loading footprints:
PARSE_ERROR: Expecting “)” in input/source
line 12 offset 215 from dsnlexer.cpp : Expecting() : line 361
never mind. Turns out I accidentally saved a broken copy into another library.Upon running into that copy, program stops reading libraries, which forced me to blame this particular design. Thanks none the less
