I’ve been trying to import a dxf into KiCAD because I wanted to do a pretty custom trace/board outline.
I’m using all straight lines and arcs so the board outline, the solder masks and everything imports without an issue.
But, it doesn’t let me choose a copper layer to import to.
Does anyone know anyway around this?
Hell, I haven’t done yet, but I’ve read some users that import to another thecnical layer (non-copper) and then they change the layer in a text editor.
I think this can help you if you are interested in artistic ground (or power) planes but I don’t really know how it will behave if you want to use it for nets traces.
Good luck and I’d like to see your progress importing dxf.
Regards
Copper can only handle straight lines, no arcs, no circles… just plain straight lines.
See here for more:
[quote=“Deppy, post:9, topic:1745”]
I’m not familiar with python. Although, I read the post but it’s not what I’m looking for in the moment but I’ll keep that in mind (when I’m in the mood for python). I prefer to create arcs in footprint editor and then convert them to copper in text editor.[/quote]
Well, I prefer to create copper spirals as tracks in python and copy&paste them into a kicad_pcb that has got the basic setup done and then enjoy myself
[image]
Code is here:
Have fu…
[quote=“suckiden, post:5, topic:1229”]
PPS: If anybody is willing to program this script/program I would be very thankful and I guess some of the community members as well…[/quote]
Here you go, pretty crude but did work for me already.
Runs on Python 2.7.2 and goes into a xyz.kicad_pcb via text-editor (I have KiCAD BZR5978).
KiCAD_CopperArc.py on Github Gist
The script pproduces the segments for an arc with the following specs (can be adjusted in the script):
Center = x 105.0 mm / y 105.0…
Take a look at https://github.com/mondalaci/dxf2svg2kicad
Draw your custom board (and connectors, etc) in any program you want, export dxf, convert to kicad_pcb. Works like a charm.
