Importing Board settings from One board to another
Hello guys I am trying to import board settings from one project to other
all setting are successfully imported, but custom rules are not getting imported.
What can be the issue?
Are you using KiCad 9? I noticed this as well and therefore copied them over manually.
It would probably be a good idea to report this on GitLab.
Edit: I tested it again in KiCad 9.0.2 and it seems to work. I think I had this issue in 9.0.0 or 9.0.1. So if yu haven’t already, make sure you are on the most recent release
I am using Kicad 8.0 version
If that is actually correct you should update to the latest V8 revision . . . V8.0.9 if its not correct, then do this first:
Can you paste your version info here please, you can get it from KiCad > Help > About KiCad > Copy Version Info
Application: KiCad x64 on x64
Version: 8.0.3, release build
wxWidgets 3.2.4
FreeType 2.12.1
HarfBuzz 8.3.0
FontConfig 2.14.2
OpenGL: Intel, Intel(R) UHD Graphics 730, 4.6.0 - Build 32.0.101.6129
Date: Jun 3 2024 19:04:47
Boost: 1.83.0
OCC: 7.8.1
Curl: 8.5.0-DEV
ngspice: 42
Compiler: Visual C++ 1939 without C++ ABI
The full information, above, that you deleted before replying with 8.0.3 is the preferred answer to Raptor’s question.
This tells us all the information that may be needed to answer questions.
You should update to the newest version in the 8.x version, which is 8.0.9
I think this should help
wxWidgets 3.2.4
FreeType 2.12.1
HarfBuzz 8.3.0
FontConfig 2.14.2
Boost: 1.83.0
OCC: 7.8.1
Curl: 8.5.0-DEV
ngspice: 42
