PcbNew, import netlist: Is there a way to make all pin #1 of a component (or lowest-number pin if #1 does not exist) snap to a the grid dots? I have used footprints which have pads on a 0.1" grid, eg DIL-08 etc.
I’m laying out veroboard
As it is, the footprints all need painstakingly moving.
Interestingly, if I first choose a 0.1" grid, then move one footprint (eg a resistor) then so far, this action seems to force the alignment of pads to the grid. If a pad was at (say) at X=5.23676", then after the ‘move’… the pads are now snapped to the grid (useful).
However, if I multi-select, this does not work (less useful).
Also Veecad might be worth looking at, especially if you already have a KiCad design. It used to be paid for but has just been made open source https://veecad.com. I have not used it but the documentation says it will work with KiCad (export ed in Orcad format) netlists.
