Is there a way to import and export a set of text variables?
If not, is this somthing that will come?
There isn’t a way to do that. If you want to create an issue in gitlab, you could suggest adding it to Schematic Setup → Import Settings from Another Project dialog.
There’s a workaround: you can create a simple spreadsheet with two columns. Copy the 2 x rows matrix. In the Text Variables page of the Schematic Setup → Project hit the + icon as many times as there are rows. Go to the 1st cell. Paste with Ctrl+V.
