Imbedded drawing sheet V9.0.0 reverts to default
From PCB, File - Page Settings, I imbed a drawing sheet from my template folder.
It looks good, I save it, close KiCad.
When I open KiCad again the sheet has reverted to the default drawing sheet even though Page Settings still shows the file that I put in.
Schematics work correctly.
Thanks,
NASA
I have replicated what you have found . . . and also figured out a workaround.
When you set the new template enter the full path and filename manually (copy & paste) and it will work.
Will you raise this as a bug on GitLab ?
Thank you, I will raise this in GitLab
Nasa
I did raise an issue this morning.
Regards,
Nasa
