For those using git as your version control for kicad projects how do you deal with the ever changing tstamp values? I’ve seen people try to hide these tstamp changes from the diff via custom difftools, but what if I just didn’t commit them?
Is there a good summary of what these values are actually used for in the code anywhere? Would it be ok for me to ignore all changes to these values in my git commits or will this inherently mess something up that refers to these values specifically?
For example I have a git diff
from just checking off the “Exempt from courtyard requirement” on one footprint. The diff is huge:
diff --git a/kicad/robot/robot.kicad_pcb b/kicad/robot/robot.kicad_pcb
index a9ccc07..b1bb616 100644
--- a/kicad/robot/robot.kicad_pcb
+++ b/kicad/robot/robot.kicad_pcb
@@ -26432,31 +26432,31 @@
(property "ki_description" "Single-cell battery")
(property "ki_keywords" "battery cell")
(path "/aaf20b87-68dc-43c9-a7d3-4ceda8b87424/0bd86b86-b1c3-4ae6-b20b-54681467bcbc")
- (attr exclude_from_pos_files)
+ (attr exclude_from_pos_files allow_missing_courtyard)
(fp_text reference "BT2" (at 0.025 16.256) (layer "B.SilkS") hide
(effects (font (size 1 1) (thickness 0.15)) (justify mirror))
- (tstamp 0591762e-645b-44a2-9db8-f2b97a416c21)
+ (tstamp 7f566b12-f92e-4caf-89f3-0abcb10035f9)
(fp_text value "DNP" (at 0.279 0) (layer "B.Fab") hide
- (tstamp 07d1089a-abc3-477c-b59f-59168b23ea6a)
+ (tstamp c3c6cca3-dfec-4633-98de-8a8a3718ac72)
(fp_text user "-" (at 34.29 0) (layer "B.SilkS") hide
- (tstamp 7647c952-2bf1-4896-b244-b9f2cabfcf09)
+ (tstamp 84e11be3-a2d5-44db-b282-bea077250b30)
(fp_text user "+" (at -34.29 0) (layer "B.SilkS") hide
- (tstamp c2910a93-785f-46ba-b4ca-476e6481587b)
+ (tstamp aadb420e-b532-4b63-b9d1-e9f62ddd8674)
(fp_line (start -39.375 -14.375) (end -39.375 14.375)
- (stroke (width 0.12) (type solid)) (layer "B.Fab") (tstamp b5eca970-a899-4c29-be96-10ff39010cb7))
+ (stroke (width 0.12) (type solid)) (layer "B.Fab") (tstamp 2f24c092-19cd-467d-8675-91493b196cc5))
(fp_line (start -39.375 -14.375) (end 39.375 -14.375)
- (stroke (width 0.12) (type solid)) (layer "B.Fab") (tstamp 2345bf1e-c693-4351-b092-d7bf54da5ac2))
+ (stroke (width 0.12) (type solid)) (layer "B.Fab") (tstamp 93642ff8-37c5-449c-aa11-87a85fb312df))
(fp_line (start -39.375 14.375) (end 39.375 14.375)
- (stroke (width 0.12) (type solid)) (layer "B.Fab") (tstamp fb87c615-2a60-4bcc-9852-57f5a7b7ccba))
+ (stroke (width 0.12) (type solid)) (layer "B.Fab") (tstamp f48a2c1f-9141-4f74-9d74-7066eae24615))
(fp_line (start 39.375 -14.375) (end 39.375 14.375)
- (stroke (width 0.12) (type solid)) (layer "B.Fab") (tstamp 62e24b51-fe70-459e-8785-643d9e181811))
+ (stroke (width 0.12) (type solid)) (layer "B.Fab") (tstamp 9d22bdd2-a414-430d-9872-76f859de381f))
(model "${KIPRJMOD}/packages3D/Battery_26650.step"
(offset (xyz -32.5 0 15))
(scale (xyz 1 1 1))
@@ -27236,26 +27236,28 @@
(attr through_hole exclude_from_pos_files)
(fp_text reference "TH1" (at -27.8 0 90) (layer "B.Fab")
(effects (font (size 0.25 0.25) (thickness 0.0625)) (justify mirror))
- (tstamp 53056479-becb-4e6b-9de0-2c2ab972ca0a)
+ (tstamp 27425e69-5d18-4d1b-a29b-2539076f9aaf)
(effects (font (size 1 1) (thickness 0.1)) (justify mirror))
- (tstamp c07d0d9d-b175-47dd-b1bb-60031f50d931)
+ (tstamp dedd0f81-e3aa-4c51-aa6a-61fb7a4b7e6d)
+ (fp_rect (start -28.6 1.9) (end -27 -1.9)
+ (stroke (width 0.05) (type default)) (fill none) (layer "B.CrtYd") (tstamp cebea502-765f-4796-ba42-2630db5d8e1f))
- (stroke (width 0.12) (type solid)) (layer "B.Fab") (tstamp be29690a-39d0-4da3-8b52-8e78f4112b9a))
+ (stroke (width 0.12) (type solid)) (layer "B.Fab") (tstamp 3714553c-0d25-4a6f-b8cc-ab95c11565a6))
- (stroke (width 0.12) (type solid)) (layer "B.Fab") (tstamp c31c9665-af10-4fea-b4bc-11704de428a7))
+ (stroke (width 0.12) (type solid)) (layer "B.Fab") (tstamp 5b8d8cc5-2df1-438b-86ac-068c65b2dea5))
- (stroke (width 0.12) (type solid)) (layer "B.Fab") (tstamp e9257aec-1bf6-4a46-b397-4e3ccd93f149))
+ (stroke (width 0.12) (type solid)) (layer "B.Fab") (tstamp 5cf3421c-0bfd-4754-ae2c-3a4ee91b0832))
- (stroke (width 0.12) (type solid)) (layer "B.Fab") (tstamp 558b7a36-51e6-4873-94bf-c97f0ca56a7a))
+ (stroke (width 0.12) (type solid)) (layer "B.Fab") (tstamp 0192999a-4951-42a9-a5c3-c376d04095d0))
(fp_rect (start -28.5 1.8) (end -27.1 -1.8)
- (stroke (width 0.1) (type solid)) (fill none) (layer "B.Fab") (tstamp c7bcb9e7-4584-4d36-a76f-69bd375d30cf))
+ (stroke (width 0.1) (type solid)) (fill none) (layer "B.Fab") (tstamp e8a5668b-f813-49bf-94f7-a6b917e3e356))
(pad "1" thru_hole circle locked (at -27.805 1.25) (size 1 1) (drill 0.5) (layers "*.Cu" "*.Mask")
- (net 31 "Net-(U12-REG25)") (pintype "passive") (tstamp e13f1faa-ec7a-4a8e-8760-c98eb0c9dbfd))
+ (net 31 "Net-(U12-REG25)") (pintype "passive") (tstamp 27006dae-480b-40b2-8794-1e2fa6d0cf40))
(pad "2" thru_hole circle locked (at -27.805 -1.25) (size 1 1) (drill 0.5) (layers "*.Cu" "*.Mask")
- (net 35 "Net-(U12-TS)") (pintype "passive") (tstamp 453bcc68-6f09-4985-b829-a2a38ed3820c))
+ (net 35 "Net-(U12-TS)") (pintype "passive") (tstamp 8523dc3f-e328-4db8-9f2d-e1bc41216a2a))
(model "${KIPRJMOD}/packages3D/NXRT15XH103FA1B040.step"
(offset (xyz -27.8 0 0))
(scale (xyz 1 1 1))
When in fact the only significant difference is:
What if I only add an edited patch of the the diff to my commit, such that I only end up committing this diff:
index a9ccc07..5404758 100644
@@ -26432,7 +26432,7 @@
