retiredfeline
You are correct, from now on I will use the terminology used within Kicad.
retiredfeline
jmk
Thanks for the explanation with images.
The part you advised had the same settings as you.
Clutching at straws, if this is a V5 conversion, is it possible that the stackup has got messed up?
davidsrsb
I’m not good at English, so I’m using a translator, but I can’t understand it.
Who is this comment for?
Is V5 the Kicad version?
The OP had said that his was a conversion of an old KiCad V.1 project. My guess was incorrect as the solution was found to be a switched off visibility
