I’m creating an “adapter” board for the power supply a 30 year old music synthesizer. The original power supply used connectors that were known as “0.062 Molex” connectors. These may be known as “Molex type 1625” but I’m not sure. The 6 pin variety was in a 2x3 rectangle with one corner cut:
Can anyone point me towards a positive ID, sources, and footprints?
Pin size and spacing are the key points. Molex used both 0.062 and 0.095 inch diameter pins. Common spacing was 0.1" and maybe 0.125 if I recall correctly.
As I look through the Kicad library for Molex, I don’t find any existing connectors with 5mm pin spacing, so I’m still not sure I’m on the right track.
Spent 12yrs as a connector design engr and manager for AMP (now Tyco) and JAE and have Patents on connectors (for Medical products) so, connector talk interests me… And, I often worked with Molex, Lemo, Takata… I love connectors!
Those red guys in the photo could be most any brand, we made many that look just like them - but, not the same…
I looked through my boxes of connectors but did not see 6 pin guys with similar latching.
Connectors are all about the Normal-Force between the contact surfaces, and a host of things will affect that good, consistent continuity.
If it were me, I’d consider making Pigtails with contacts on wire or replacing them.
A cheap, but useful approach is to put contact on wire and goop them-up with Hot-Glue - not a pro solution but, we often did it for quick testing (top one in photo…) Don’t melt the wire insulation!
