[KiCad 6.0.1-0] Can someone explain the “Id:” field on the schematic in the lower right corner, title block area?
I have a hierarchical schematic with a root page and 4 sub pages.
Upon opening KiCad, my project, and my schematic, the root page shows “Id: 1/1” in this field. If I open the Page Settings dialog, make no changes, and then close it my clicking OK, this field changes to “Id: 1/5”. (If I open the Page Settings dialog and close it by clicking Cancel, this field remains at “Id: 1/1”.) After saving my schematic with this field showing “Id: 1/5” on the root page, upon closing out of KiCad and then reopening, this field reverts to “Id: 1/1” on the root page.
The remaining four pages always all show the same “Id: 5/5”, with no changes on opening and OK’ing the Page Setting dialog.
I have never seen “Id: 2/5”, “Id: 3/5”, or “Id: 4/5”, as I might expect, anywhere.
I don’t see any way to directly control this Id field from the Page Settings dialog.
Do these Id numbers do anything in KiCad? Are they related at all to the netlist? I have my board laid out and all the checks I can find to perform seem ok.
Very early on, I started my board without using the hierarchical features. I then decided to change to hierarchical when it became clear my project was too big for one page. I did some early copy and paste among sheets without using the “paste special” features, which I have just run across in trying to research this problem. It seems to have all worked out with my board, but as such, I’m probably not on a typical workflow, so I may be tripping into some corner here.
I’d like to get my schematic to where the Id: field makes sense. I also want to make sure that this is not a hint to some deeper problems in my project.
I’m new to KiCad, just starting with the release of version 6. I must say I’m very impressed! This is an amazing tool. Thanks to all for creating this!
