Hi
Pads overlap like this.
i want to make it like this(Modified with Paint)
please let me know if there is a way
Thanks
Hi
Thanks
Answer study board design rules)
KiCad does not have drawing capabilities like that. On top of that, the clearance between the pads is narrower then the clearance defined by rules (the tin yellow line), and this would cause a DRC violation.
There are (at least) four things you can do in KiCad:
With a combination of those you can probably make something “acceptable” (although not ideal).
