I want to open raspberry pi project
I’m a newbie of KiCAD.
I want to open the Raspberry Pi CM4 IO Project.
However, I can’t open the project and I see the message,
KiCad_RP-CM4_IO_PCB_Open_Error
I re-installed the KiCad version 5.1.10_1.
(which was uploaded at 2021-05-01T11:58:13.425Z in the https://kicad-downloads.s3.cern.ch/index.html?prefix=windows/stable/)
How to fix this problem?
Unfortunately the Raspberry Pi team decided to use a nightly build of KiCad instead of the stable release to make the CM4IO, so you cannot open it with 5.1.10
To open this file, you’ll need to install a nightly build.
See Is it a good idea to use a nightly build version? for some cautions.
Jump off a 30 meter cliff without knowing the water depth? Sure why not? :smiley:
I have been happy with many of the nightly versions and I suspect that many others have been also. I am no software expert…
