I am using version 6.0.6. It is not an error, but I couldn’t find an answer. I am trying to delete fab reference text. Delete does not work and right click delete does not work. I also wanted to delete the reference text on the silkscreen as well.
You cant delete Ref-text on Silkscreen/Fab-layer as these are normally mandatory text-fields in the footprint. But you can set these items to “invisible”. (doubleclick an Ref-text-item. In the opened properties-dialog is a checkbox for “visible”).
If you want to change this setting for many/all ref-texts: use the Edit–>Edit text&Graphics properties-tool.
