My project uses a number of PCB’s. Can I display then under one heading - or is each board
a separate entry within KiCad ?
KiCad assumes one project per board.
If your project consists of multiple boards connected with connectors (Such as IDC), Then it’s probably a good Idea to make a custom library for those connectors, and assign pin names to the connectos, much like as is usually done with IC’s.
This helps in preventing wiring mistakes.
