The projection should affect only the geometry of the view, not other things. I think there’s something else going on. You should give the exact version information from Help → About → Copy Version Info. You should also tell if you have tried the Preferences. There are quite many settings which may effect to the visuals.
Platform: Windows 10 (build 22000), 64-bit edition, 64 bit, Little endian, wxMSW
Date: Mar 18 2022 03:04:44
wxWidgets: 3.1.5 (wchar_t,wx containers)
Boost: 1.76.0
OCC: 7.6.0
Curl: 7.78.0-DEV
ngspice: 36
Compiler: Visual C++ 1928 without C++ ABI
KICAD_USE_OCC=ON
KICAD_SPICE=ON
The only thing I remember changing in the setting was the board color to blue (#02057AC4)
I will try clicking in the “reset to default” everywhere and see what happens
