please explain ?
something strange… 0 ohm comes out as 3 blacks and gold, but so did the 100 ohm…
of course i can cut and paste the brown for the 100 ohm
EDIT… also the 1K start with black even thou that is not possible… or is it just me?
but only seems to be when ohm is 0 or starts with 1 and are followed by zero’s, 1500 ohm is ok
Something very odd
i did manual edit on the 1K and it still starts with a black even thou the wrl says brown
i even tried to remove it and update 3d view and then add it again
this is the 1k as is:
is not much mistaken it should make brown black red and gold rings, but it does show up as black brown gold gold
EDIT: i think the first “error” is that the python script does not get each ring a different number
and then for some reason if value is 10, 100, 1000 etc etc it will not start with a brown
with a lot of edit work i got it sorted
but i still think the pyton script suffers from the 2 issues in last post
anyway a big thanks for it, it helped out a lot
Sorry, that was a work in progress and had several bugs. I think I fixed those, and also the script now can update a kicad_pcb file. Currently the value must be a plain number, eg. 4700.
I think it is ok, but I would strongly suggest making a copy of your pcb file before running the script on it
#!/usr/bin/env python
# -*- coding: utf-8 -*-
# Name: gen_model
# Purpose: A script to create a 3d resistor model (WRL) with color correct rings according to value.
# Note : this version works with KiCad v4 or v5
# Author: Bob Cousins
# License: Creative Commons CC0 Copyright Bob Cousins 2018
# Credits: Input for the resistor models requires https://github.com/KammutierSpule/kicad3Dmodels
# Usage:
# 1. Save the file "gen_model.py" somewhere
# To generate a file for a single resistor:
# $ python -v <value>
# where value is a decimal, e.g.
# $ python -v 4700
# To update a pcb file with resistor models:
# 1. Make sure the pcb file is closed in KiCad
# 2. $ gen_model.py -pcb <pcb file>
# 3. Open the pcb file in KiCad
import argparse
import shutil
import os
import sys
import re
#import pcbnew
class ModelGenerator:
def __init__(self):
self.source_folder = 'C:/github/kicad3Dmodels/generated/Resistors/Film_Carbon'
self.bands = 4
if 'KISYS3DMOD' in os.environ:
self.ki_packages3d_dir = os.environ['KISYS3DMOD']
else:
self.ki_packages3d_dir = 'C:/github/kicad3Dmodels/generated/Resistors/Film_Carbon'
self.custom_folder = os.path.join (self.ki_packages3d_dir, "Resistors_THT_custom.3dshapes")
if not os.path.exists (self.custom_folder):
os.makedirs(self.custom_folder)
def get_model_filename (self, value):
return 'res_%dband_%g.wrl' % (self.bands, float(value))
def generate_model (self, value):
dest_name = os.path.join (self.custom_folder, self.get_model_filename (value))
# copy the resistor model
res_body_filename = 'RESAD780W55L630D240B.wrl'
shutil.copy (os.path.join(self.source_folder, res_body_filename), dest_name)
# copy the rings
outf = open (dest_name, "a")
transforms = []
transforms.append ("translation -.90 0 .51 scale .55 1.22 1.22")
transforms.append ("translation -.53 0 .51 scale .55 1.04 1.04")
transforms.append ("translation -.18 0 .51 scale .55 1.03 1.03")
if self.bands == 5:
transforms.append ("translation .17 0 .51 scale .55 1.03 1.03")
transforms.append ("translation 0.80 0 .51 scale .55 1.22 1.22") # tolerance
mag = 0
max = 100 if self.bands == 4 else 1000
while value < max/10:
mag -= 1
value *= 10
while value >= max:
value /= 10
mag += 1
# 4/5 band code
digits = []
if self.bands == 5:
digits.append ((value / 100) % 10)
digits.append (int(value / 10) % 10)
digits.append (int(value) % 10)
if mag>=0:
digits.append (mag)
elif mag == -1:
digits.append (10) # gold = x0.1
elif mag == -2:
digits.append (11) # silver = x0.01
# 10 is gold, 11 is silver
digits.append (10)
for j in range (0,self.bands):
digit = digits [j]
source_filename = os.path.join(self.source_folder, 'ring_%d.wrl' % digit)
with open(source_filename) as file:
ring_data = [line.rstrip() for line in file]
seen_start = False
for line in ring_data:
if "geometry" in line and not seen_start:
outf.write ("Transform { %s children [ \n" % transforms[j])
seen_start = True
else:
line = re.sub ("RES-RING-COLOR", "RES-RING-COLOR-P%d" % j, line)
outf.write (line + '\n')
outf.write (" ] }")
outf.close()
# this function does not work..
def pcbfunc(Filename = None):
if Filename:
my_board = pcbnew.LoadBoard (Filename)
else:
my_board = pcbnew.GetBoard()
# for v5 use GetLibItemName() instead of GetFootprintName()
for module in my_board.GetModules():
models = module.Models()
print ("%s \"%s\" " % ( module.GetReference(),
module.GetValue() ))
#module.GetModels() ) )
print models
def change_extension (filename, ext):
path, filename = os.path.split (filename)
basename = os.path.splitext (filename)[0]
return os.path.join (path, basename + ext)
def get_next_line(file):
line = file.readline()
if line:
line = line.rstrip()
return line
def parse_pcb(Filename, model_gen):
f = open(Filename, 'r')
outfilename = change_extension (Filename, ".new")
out = []
line = f.readline()
while line:
if "module" in line:
tokens = line.split()
module = tokens[1]
# print module
out.append (line)
line = get_next_line(f)
while line and line != " )":
if "model" in line:
model = tokens[1]
# print " model=" + tokens[1]
if "Resistors_THT" in module :
# check if alrady exists?
# check pitch?
model_gen.generate_model (float(value))
line = " (model ${KISYS3DMOD}/Resistors_THT_custom.3dshapes/%s" % model_gen.get_model_filename (value)
else:
line = " (model %s/%s" % (model_gen.custom_folder, model_gen.get_model_filename (value) )
print module
print " value = ", value
print " model = ", model_gen.get_model_filename (value)
out.append (line)
out.append (" (at (xyz %f 0 0))" % (0.3/2.0) )
out.append (" (scale (xyz 1 1 1))")
out.append (" (rotate (xyz 0 0 0))")
out.append (" )")
# skip 4 lines
elif "value" in line:
value = tokens[2]
# print " value=" + value
out.append (line)
out.append (line)
line = f.readline()
f.close()
f = open(outfilename, "w")
for line in out:
f.close()
shutil.copy (outfilename, Filename)
# main
try:
args = sys.argv
except:
args = None
if args:
parser = argparse.ArgumentParser(description="Generate resistor model")
parser.add_argument("-v", "--value", help="resistor value")
parser.add_argument("--pcb", help="kicad_pcb file")
args = parser.parse_args()
if args.value:
model_gen = ModelGenerator ()
model_gen.bands = 4
model_gen.generate_model (float(args.value))
elif args.pcb:
model_gen.bands = 4
parse_pcb (args.pcb, model_gen)
else:
parser.print_help()
# pcbfunc()
