I can't open any tools 9.0
Hi With the first installation, I can’t use Schematic, symbol, footprint and PCB when I click to use the tools it quick outside.
The installation are work fine I have windows 10
In any such case when something ‘don’t working’ you should give exact information about KiCad version.
It is important if you mean 9.0.0 - very buggy as first release of V9 or 9.0.3 last release with many bug already fixed.
Can you paste your version info here please, you can get it from KiCad > Help > About KiCad > Copy Version Info
Application: KiCad x64 on x64
Version: 9.0.3, release build
wxWidgets 3.2.8
FreeType 2.13.3
HarfBuzz 10.2.0
FontConfig 2.15.0
Date: Jul 8 2025 05:19:33
Boost: 1.88.0
OCC: 7.9.1
Curl: 8.13.0-DEV
ngspice: 44
KICAD_IPC_API=ON
Locale:
Lang: en_GB
Enc: UTF-8
Num: 1,234.5
wxWidgets 3.2.8
FreeType 2.13.3
HarfBuzz 10.2.0
FontConfig 2.15.0
Boost: 1.88.0
OCC: 7.9.1
Curl: 8.13.0-DEV
ngspice: 44
KICAD_IPC_API=ON
Locale:
Lang: en_GB
Enc: UTF-8
Num: 1,234.5
I’m not sure what this part of the sentence means.
Can you record a video of what isn’t working?
I see where is the problem, the graphic card are to old, I changed and it work
Providing the exact model number of your hardware may be helpful when sharing information with others on the web.
We also encourage you to provide screenshots and the exact spelling of any text strings you see when performing this action.
This information is the minimum required to share information in the knowledge base (including disclosing version information, etc.).
In fact, there are cases where you can solve the problem without buying new hardware.
ex.:
