I can’t draw tracks anymore. I was finishing my pcb, this
error appeared : ErrType(27) - Too small track width.
Have you any idea ?
Check your Design Rules settings for the Net Class Default value and then the Global Design rules tab… something in there must be set so you get a problem.
Thanks for your help.
Minimum Allowed values where bigger than default.
OK to rename this thread with (SOLVED)?
sure, I did that the first 3-4 times I came across situations that had been solved, but lost the habit again
