I’m using KiCAD 8.0.5 and having a problem getting a new footprint associated with its symbol.
Here is the version information:
Application: KiCad x64 on x64
Version: 8.0.5, release build
wxWidgets 3.2.5
FreeType 2.13.2
HarfBuzz 9.0.0
FontConfig 2.14.2
libcurl/8.8.0-DEV Schannel zlib/1.3.1
OpenGL: Intel, Intel(R) HD Graphics 4600, 4.3.0 - Build 20.19.15.5063
Date: Sep 7 2024 02:39:48
wxWidgets: 3.2.5 (wchar_t,wx containers)
Boost: 1.85.0
OCC: 7.8.1
Curl: 8.8.0-DEV
ngspice: 42
Compiler: Visual C++ 1939 without C++ ABI
I downloaded from Ultra Librarian a zip file with the schematic symbol and footprint of a Wago
terminal; Wago part number 2065-100/998-403. I’ve attached the zip file to this posting. {Upload failed, new users cannot post attachments. }
In spite of my best efforts over a day and a half, I have not been able to get the footprint to
update in the PCB Editor after successfully placing the symbol in the Schematic Editor. Here
is the pretty complete but way-too-long-winded blow by blow of installing the symbol and
footprint and then trying to do an update:
From the main Project Files window, open the Schematic Editor
Select
Choose tab “Project Specific Libraries”
Choose folder-shaped icon “Add Existing Library to Table”
Double Click on .kicad_sym file:
“D:\KiCAD\Projects\UPV-01-2021.001_DevRev5\ul_2065-100-998-403\KiCADv6\2024-10-19_05-24-58.kicad_sym”
The “Project Specific Libraries” tab now contains 1 library entry:
Active: Checked
Visible: Checked
Nickname: 2024-10-19_05-24-58
Library Path: ${KIPRJMOD}/ul_2065-100-998-403/KiCADv6/2024-10-19_05-24-58.kicad_sym
Library Format: KiCad
The list of Available Path Substitions includes an entry I previously made:
${KIPRJMOD} D:\KiCAD\Projects\UPV-01-2021.001_DevRev5
Click OK to close the Symbol Libraries Window
Select the “Switch to PCB Editor” icon
Select
Choose folder-shaped icon “Add Existing”
Select the footprints.pretty folder shown below, and click button “Select Folder”
“D:\KiCAD\Projects\UPV-01-2021.001_DevRev5\ul_2065-100-998-403\KiCADv6\footprints.pretty”
Active: Checked
Nickname: footprints
Library Path: ${KIPRJMOD}/ul_2065-100-998-403/KiCADv6/footprints.pretty
Options:
Description:
Click OK to close the Footprint Libraries Window
Select the “Switch to Schematic Editor” icon
Select the “Add Symbol” icon
In the Search bar, type in the Wago part number: 2065-100/998-403
The correct symbol is found and displayed in the top right of the Choose Symbol window, but
in the bottom right where a preview of the footprint should appear it is black and the
message: “Invalid Footprint Specified” is displayed. Above the footprint preview is:
[default] CONN_2065-100/998-403_WAG
Select OK to close the Choose Symbol window.
The Schematic Editor appears, and the crosshair drags the symbol until left-clicking places it.
Select the “Update PCB from Schematic” icon
The Update PCB from Schematic window appears with this error in the Changes to Be Applied box:
Processing symbol ‘J1:CONN_2065-100/998-403_WAG’.
Error: Cannot add J1 (footprint ‘CONN_2065-100/998-403_WAG’ not found).
Total Warnings: 0, Errors: 1.
Again, I’m sorry for the length of this post. Thank you very much for any help you can offer!
Dave
