Http://docs.kicad-pcb.org appears to be down
http://docs.kicad.org appears to be down. Is it being updated?
There does not appear to bey any html files, only empty directories and images
There was a zip file with all of the html docs in the root directory, which I uploaded to my own server. You can see them at: https://www.theotherrealm.org/kicaddocs/ for a temporary solution
This topic might help:
Hi, just for information, that place is up again. There were just a hiccup with the build configuration that made empty artifacts, which meant that it would look empty. But it should work fine now.
