Hi @brainstorm, In IPC-7351B terms it would be something like SOP80P990X220-28. It is quite specialised, so you’ll probably end up making it yourself.
Use the “New footprint using footprint wizard” (in the footprint editor) , template SOIC. Set number of pins to 42 and delete the middle 7 pins on the middle of each side (and renumber the remaining pins to match the device), then you will have to manually add the GND pad.
Hi @brainstorm, No problem. I would advise that you change the silkscreen outline to the F.Fab layer or modify it as it is crossing pad #1 (cutting the corner).
Also, i think you should change the heatsink pin numbers to something else, like #29 (they can be the same pin number), otherwise you will have a conflict (the heatsink pins will connect to a different net (GND) compared with the small pin #1 and pin #2).
Yeah, true on both suggestions, I found myself changing it while I was fiddling with the PCB layout, here it is if someone else needs it in the future:
