gmc
                    January 11, 2023,  6:03pm
                  1
              Updating this to be more of a tuorial is it’s fairly easy to implemented.
To use teardrops go to PCB Editor. Under  Tools you can add and remove teardrops which will then be added/removed from your PCB.
Teardrops are added as zones
and can be viewed in the 3D  viewer:
If you do not see them then make sure Objects Manager / Objects / Zones  is enabled, and your zones are filled, as they are added as zones.
              They do work for me, and they appear to be created as “special zones”.Objects Manager / Objects / Zones
                gmc
                    January 11, 2023,  6:34pm
                  3
              I can select the teardrop on PCB Editor but when checking on 3D viewer I don’t see it.
Is it working for you in the viewer?
              Yes, they show up in the 3D viewer too:
The 3D viewer still does not render solder fillets though…
                eelik
                    January 11, 2023,  8:33pm
                  5
              You have to fill zones because teardrops are zones.
                gmc
                    January 11, 2023,  9:55pm
                  6
              Ahh yes of course.
Thanks, was as simple as that.
                paulvdh
                    January 12, 2023, 12:34am
                  7
              I thought I already mentioned the Zone  thing in my first reply…
The tile you make for this topic has a nice name. I guess lot’s of people are going to find it in the future. I did not answer to your question of how the parameters work exactly. Can you update your first post and make it in a mini tutorial for this topic?
                gmc
                    January 12, 2023,  9:58am
                  8
              You did but it didn’t register
I’ll update the OP and add in the details.
                paulvdh
                    January 12, 2023, 10:15am
                  9
              Thanks for the feedback.
                LM21
                    January 15, 2023,  8:51pm
                  10
              What if adding a teardrop causes a clearance error. Is the tool clever enough to prevent that
                Naib
                    January 15, 2023,  9:04pm
                  11
              from playing around yes. It won’t add them if it can’t but typically if you have tracked from a via you must have had clearance to track out
                eelik
                    January 15, 2023,  9:21pm
                  12
              It doesn’t prevent clearance errors but it doesn’t cause them, either. Because they are small zones, they are filled so that they avoid other nets. They don’t keep their shape by force.
                LM21
                    January 16, 2023,  6:27am
                  13
              Ok. So, I can add teardrops to whole board. PC board looks much better with teardrops, more professional.
                barrie
                    January 18, 2023,  4:46pm
                  14
              Love the teardrop but There may be a problem with isolation. Straight line teardrops (on my PCB) reduced track to GP from 0.6mm to 0.48mm. Curved line tear drops reduced track to GP to 0.8.
              Did you refill the zone after? (B)
                barrie
                    January 18, 2023,  5:41pm
                  16
              No,  and thank you for the reminder it is good after refill.
                LM21
                    January 19, 2023,  6:28pm
                  17
              Is this Plug-in only available for ver 6.99-7.00
                eelik
                    January 19, 2023,  6:44pm
                  18
              This isn’t a plugin, it’s a new native implementation in 6.99/7.0.
                LM21
                    January 19, 2023,  7:07pm
                  19
              Ok, I’ll wait for release candidate               Aha, spaces are not counted in 20 chars.
                hmk
                    January 19, 2023,  7:53pm
                  20
              7.0.0 release candidate 1 is out already.
