How do I use the .bak of a schematic? btw - I’ve tried searching for an explanation with no luck. Only found a brief definition of .bak file format. Changing the .bak to .sch didn’t work as it gave me an error when I tried to open it.
TIA
TIA
I think it should work as you described; so it appears that something else may be wrong or corrupted.
I’d open both files in a text editor and try to determine what is going on.
Can you post your file here?
@iabarry I’d suggest uploading both files; as your permissions allow.
I’ve likely botched it. Will just rebuild from a prior rev.
Thanks for the offers tho.
Nothing KiCad does should lead to a corrupt file. Only PC crashes or hand editing the file should cause this, which is why we are interested to see a sample
