Thank you for your reply.
I did it but when I launch the simulator from the Tool menu, error messages are displayed:
“Missing ngspice shared library” then
"an unhandled exception occurred. Press “Abort to terminate the program,“Retry” to exit the program normally and “Ignore” to try to continue”.
Ignore and Retry have the same effect:
“Failed to load shared library ‘ngspice.dll’ (error 126: le module spécifié est introuvable.)”.
No trace of any ngspice.dll on my HD.
Reverting to ver #27 is working again.
if I copy the ‘dll-vs’ sub-directory of the zip file containing ngspice.dll or if I put it along with libngspice-0.dll that doesn’t work either: similar error messages.
I’m running windows 7 French version with an English version of kicad. It might be the reason of the message that’s partly in French language.
TIA.
With KiCad 32 bit the update procedure will not work, and you would have to re-install KiCad 32 bit completely, as ngspice-30 is now offered by KiCad 5.1.2.
Please post the KiCad version info here (Eeschema -> help -> version info).
It might just be easier for you to reinstall KiCad. There was a rebuild of the Windows version to include ngspice 30 “in the box” that is distributed as 5.1.2_2 (see the download link in Holger’s message). The underscore 2 may not show in the version information because that is a second version of the installation packaging (to update the bundled ngspice), and not a change to the base KiCad suite.
I haven’t tried this myself yet, but you should hopefully be able to install 5.1.2_2 on top of your current install and that should update the bundled ngspice. If not, try uninstalling your 5.1.2 and then reinstalling with the 5.1.2_2 distribution package.
My mistake, I’m really feeling old when I do such kind of errors !
I installed the wrong version. Two or three weeks ago, I downloaded both 5.1.2-2 and 5.1.4 on my disk and clicked on the wrong executable when I installed it.
Everything is running fine at the moment.
Thanks again.
happens, no need to feel old, It has happened to me as kid, teen, young adult, adult and most probably will keep happening, somebody got a good laugh out of it and that is what matters
