How to tent in-pad vias? (for thermal pads)
Yes, here is the document I was originally looking at. I hadn’t come across this either (am not experienced), just looking at what the manufacturer was recommending.
https://www.ti.com/lit/slma002
it possible with a bit of working, creating a footprint with the right mask zone, using polyline pads (drills 0.3, mask 0.1 annular larger)
or you could do something like this:
– edit –
an example HSOIC8
Unfortunately not, Solder Mask Defined is required to be communicated through notes by some manufacturers, and I have received a set of boards where a couple of them was modified by hand, apparently someone tried to scrape off some mask with a sharp object after manufacturing, but then they gave up and the rest of the boards were intact. Only later I understood that they didn’t understand we wanted the mask just like we had defined it.
just for fun I’ve tested this footprint w/ polyline pads… and here the result:
produced without having to communicate any special instruction to the manufacturer and tenting the thermal vias in the thermal pad to reduce solder loss.
