I am trying to make my first PCB in KiCAD and I have a problem - I want thick power traces. By I also want to tie some Enable pins to Vcc - is there a way to make the power trace thick only to the Vcc pin but traces from Vcc to the Enable pin only narrow?
Thanks
I think if you do a custom width track under global design rules it appears in the drop down menu at the lower left tool bar and you can then choose it at any time. I don’t have time to double check right now though. One kludge would be to do a small copper fill to that pin.
