How to specify symbols with '/' in name in a database library?
I am trying to use the database libraries in KiCAD. So far, the basic setup works. However, I found out that symbols that contain a forward slash (‘/’) appear in the symbol selector; however, they have no name and no fields. Instead of name, there is __NAME__, instead of fields, there is __FIELDS__. See the attached screenshot.
How should one specify a component that has a forward slash in the name using the DB libraries?
it could be useful if you could attach your .kicad_dbl file (or a section of it)
This is the relevant DB row:
                            name                             |                                     symbol                                   |                        footprint     | stock | on_order | price | lead_time | country_of_origin
 IO_IsolatedAmplifireWithDC/DCconverter_AMC130M02DFMR_SOIC20 | symbol_drawings:IO_IsolatedAmplifireWithDC/DCconverter_AMC130M02DFMR_SOIC20  | footprint_drawings:SOIC20_DFM_TEX    | 2898  |     5950 |   32  |        84 |
This is the relevant part of .kicad_dbl file:
"libraries": [
            "name": "",
            "table": "converters",
            "key": "name",
            "symbols": "symbol",
            "footprints": "footprint",
            "fields": [
                    "column": "stock",
                    "name": "On stock",
                    "visible_on_add": false,
                    "visible_in_chooser": true,
                    "show_name": true,
                    "inherit_properties": true
                    "column": "on_order",
                    "name": "On order",
                    "show_name": true,
                    "column": "price",
                    "name": "Price",
                    "show_name": true,
                    "column": "lead_time",
                    "name": "Lead time",
                    "show_name": true,
                    "column": "country_of_origin",
                    "name": "Country of origin",
                    "show_name": true,
            "properties": {}
