Hello Everyone,
Can you advise how do I specify PTH in KiCAD? Would that be on the footprints?
I’m trying to get JLC to make some boards but they need me to specify the PTHs on the files send to them.
I’m very very new to this, and in fact this is my first project
Many thanks in advance.
RF
You can open the footprint in the footprint editor, select the pad, and examine its properties. Here a screenshot of the properties dialog box of a diode pad. Notice the dropdown for Pad type.
Through hole pads are by default plated. To have non plated holes, the “pad type” in the properties dialogue box (posted by @retiredfeline above) needs to be changed - as far as I know, one pad at a time.
The number of plated and non plated holes can be checked in the drill file. See File / Fabrication Outputs / Drill File at the top of Pcbnew.
While generating Drill Files (File-Fabrication Outputs-Drill (.drl) File or button at down-right corner in Plot (File-Plot…) window) uncheck the “PTH and NPTH in single file” option and you will get two files - one with PTH and one with NPTH and everything should be clear.
