In KiCad 5.1.6, how do you set the default line thickness for graphic lines? It defaults to 0.15mm which is too thick to see the snaps, other lines, etc. when zoomed in.
The “Edit Text & Graphic Properties” dialog can be used to change the thickness of existing lines, but doesn’t seem to affect the default value.
[EDIT] oop’s ! Forgot: It won’t stick unless you do it for the Template’s PCB. I setup several templates for my different PCB shapes (including my default). They stick if doing that way. You can edit the Default template and set it…
