How to set active LOCAL library in footprint editor
#1
I’m a newbee user of Kicad version 4.0.6
I need to create new footprint library elements, this is in itself no problem.
The problem is that I can’t set an “active library” to store the newly created footprint. I think the first problem is that I have to create an local footprint library.
In Preferences/Footprint Library Manager I see the tab “project specific library” but this is and remains empty.
#2
Do you see/have this button in your KiCAD version (screenshot is from a nightly version)?
or this option in the File menu?
#3
@Joan_Sparky
Yes I have/see both.
But after creating something here, and storing it in a local .pretty , I can’t retrieve it. I learned from other remarks that I better would create an local library and set this to active.
#4
Now you need to append the recently created library to your project.
Preferences -> Footprint library manager
#5
As @pedro says and I wrote here (project specific depicted in image):
If you want to have this new library for all projects you do the same steps, just in the global tab.
#6
The steps “Preferences -> Footprint library manager” worked, and I could retrieve. Thanks.
Why is the “set active library” for local footprints not working ?
#7
I don’t understand that question. What are you trying to do?
#8
The set active library command is only needed in the library editor. For general use, all the libraries into the project are available.
#9
@pedro and Joan
Understood about the availability of the libraries. THANKS
but… In library editor, can you set a local library to active ? I ask this because when I want to create add a second footprint to the library the file is overwritten with the new footprint.
#10
It is not overwritten if you save the footprint with a different name.
#11
Creating a new library takes a roundabout route, but I think you are already past that.
However, once you have created a library, and added an entry for it in the global or project library table, then the process is the same for any library
  1. Open footprint editor
  2. “Select active library” -> choose library
  3. “New footprint” OR “Load footprint from library” to edit an existing one.
  4. edit the footprint
  5. “Save footprint in active library”
